[GRASS-dev] Re: [GRASS GIS] #759: r.patch non-functional in WinGRASS 6.4 svn on Vista
GRASS GIS trac at osgeo.org
Fri Jan 8 15:09:13 EST 2010
  Reporter:  cmbarton         |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  critical         |   Milestone:  6.4.0
 Component:  Raster           |     Version:  6.4.0 RCs
Resolution:                   |    Keywords:  r.patch, wingrass
  Platform:  MSWindows Vista  |         Cpu:  Unspecified
Comment (by hellik):
 Replying to [comment:3 glynn]:
 > Replying to [comment:1 helena]:
 > > I just posted the exact same issue year ago and then, forgetting the
 answer, couple weeks ago again.
 > > It is the VISTA UAC problem
 > So why does it only affect r.patch? What does r.patch do that other r.*
 modules don't?
 from the dev-ml:
 FWIW, I don't consider that to be a particularly good guess. r.patch
 doesn't appear to be doing anything remotely out of the ordinary.
 Has anyone considered that "patch" might be triggering an anti-virus
 rule? More generally, has anyone who can actually reproduce this tried
 to perform any meaningful investigation (e.g. checking system logs)?
 tested on a fresh grass64-relbranch-build on WinVista32
 r.patch started from Msys:
 GRASS 6.4.0svn (nc_spm_08):c:/ > r.patch
 sh: /c/OSGeo4W/apps/grass/grass-6.4.0svn/bin/r.patch: Bad file number
 r.patch started from the wx-gui-command line, the MSVista UAC pops up with
 following message (translated from german)
 r.patch.exe
 nicht identifizierter Herausgeber - ''no identified publisher''
 "C:\OSGeo4W\apps\grass\grass-6.4.0svn\bin\r.patch.exe" --interface-
 description
 after allowing to continue a next error-message pops up:
 r.patch.exe - Komponente nicht gefunden - component not found
 Die Anwendung konnte nicht gestartet werden, weil
 libgrass_gis.6.4.0svn.dll nicht gefunden wurde. Neuinstallation der
 Anwendung könnte das Problem beheben. - ''The application could not be
 started, because libgrass_gis.6.4.0svn.dll could not be found.''
 and afterwards r.patch crashes
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/759#comment:6>
