[GRASS-dev] Re: [GRASS GIS] #759: r.patch non-functional in WinGRASS 6.4 svn on Vista
GRASS GIS trac at osgeo.org
Fri Jan 8 15:19:46 EST 2010
  Reporter:  cmbarton         |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  critical         |   Milestone:  6.4.0
 Component:  Raster           |     Version:  6.4.0 RCs
Resolution:                   |    Keywords:  r.patch, wingrass
  Platform:  MSWindows Vista  |         Cpu:  Unspecified
Comment (by hellik):
 Replying to [comment:6 hellik]:
 > r.patch.exe - Komponente nicht gefunden - component not found
 > Die Anwendung konnte nicht gestartet werden, weil
 libgrass_gis.6.4.0svn.dll nicht gefunden wurde. Neuinstallation der
 Anwendung könnte das Problem beheben. - ''The application could not be
 started, because libgrass_gis.6.4.0svn.dll could not be found.''
 > and afterwards r.patch crashes
 > Helmut
 and in the wx-gui-command-output:
   File "c:/OSGeo4W/apps/grass/grass-6.4.0svn/etc/wxpython/wx
 gui.py", line 466, in OnRunCmd
 self.goutput.RunCmd(cmd, switchPage=False)
   File "c:\OSGeo4W\apps\grass\grass-6.4.0svn\etc\wxpython\gu
 i_modules\goutput.py", line 352, in RunCmd
 menuform.GUI().ParseCommand(cmdlist, parentframe=self)
 i_modules\menuform.py", line 1818, in ParseCommand
 xml.sax.parseString(getInterfaceDescription(cmd[0]).decode(e
 nc).encode("utf-8"),
 i_modules\menuform.py", line 1757, in
 raise IOError, _("Unable to fetch interface description for
 command '%s'.") % cmd
 IOError
 Unable to fetch interface description for command 'r.patch'.
Ticket URL: <http://trac.osgeo.org/grass/ticket/759#comment:7>
