[GRASS-dev] Re: [GRASS GIS] #759: r.patch non-functional in
WinGRASS 6.4 svn on Vista
trac at osgeo.org
Fri Jan 8 19:50:53 EST 2010
#759: r.patch non-functional in WinGRASS 6.4 svn on Vista
Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Raster | Version: 6.4.0 RCs
Resolution: | Keywords: r.patch, wingrass
Platform: MSWindows Vista | Cpu: Unspecified
Comment (by glynn):
Replying to [comment:12 hamish]:
> sigh. what a complete pile of poo.
+1
For the record, I'll include a copy of the referenced MSDN article:
[http://msdn.microsoft.com/en-us/library/aa905330.aspx]
Someone who cares about Windows (my "caring about Windows" level just
dropped by a large margin after finding out about this) might want to look
into how to create a "manifest" and whether this actually solves the
problem.
Also:
1. Is this caused (in whole or in part) by GRASS being installed somewhere
other than the "Program Files" directory? If it is, then I care even less.
If there are still problems with spaces in $GISBASE, we should fix them,
rather than expecting GRASS to be installed somewhere else.
2. Is this relevant:
Note The "User Account Control: Detect application installations and
prompt for
elevation" setting must be enabled for installer detection to detect
installation
programs. This setting is enabled by default and can be configured using
the
Security Policy Manager snap-in (secpol.msc) or with Group Policy
(gpedit.msc).
I.e. if you disable that setting, does the problem go away?
If it does, then "problem solved", IMNSHO.
Ticket URL: <http://trac.osgeo.org/grass/ticket/759#comment:13>
