[GRASS-dev] Re: [GRASS GIS] #842: wx location wizard: spincontrol
busted for UTM zone
trac at osgeo.org
Fri Jan 8 19:59:09 EST 2010
#842: wx location wizard: spincontrol busted for UTM zone
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords: location wizard, utm
Platform: Linux | Cpu: x86-64
Comment (by hamish):
Replying to [comment:17 cmbarton]:
> I've changed the UTM Zone entry widget to a simple text widget
> with validation to keep it within the 1-60 range. I've added a
> new patch here: location_wizard.patch3. Please test.
Yes it works if you type in zone=1-60.
I'm seeing that +lon_0=-183 again though and I figured out how to
reproduce it. If you enter "0" or "99" for the zone it automatically
resets to zone 1 or 60, respectively. Apparently this is only visually. If
you proceed to the summary page in the location wizard instead of +zone=23
you will see +proj=tmerc +lon_0=411 etc. ...
-PROJ_INFO-------------------------------------------------
proj : tmerc
datum : wgs84
ellps : wgs84
lat_0 : 0
lon_0 : -183
k : 0.9996
x_0 : 500000
y_0 : 0
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : Meter
units : Meters
meters : 1
fwiw1: I notice that PROJ_UNITS is uppercased, which seems different to
how I always seem to have remembered it there.
fwiw2: I notice this patch no longer has the try: row/column stuff.
(different things should go into 2 different commits I guess)
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/842#comment:18>
