[GRASS-dev] Re: [GRASS GIS] #842: wx location wizard: spincontrol busted for UTM zone
GRASS GIS trac at osgeo.org
Fri Jan 8 20:09:51 EST 2010
  Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:  location wizard, utm
  Platform:  Linux     |         Cpu:  x86-64
Comment (by hamish):
 Replying to [comment:18 hamish]:
 > fwiw1: I notice that PROJ_UNITS is uppercased, which seems
 > different to how I always seem to have remembered it there.
 this may be problematic, I see that lib/gis/proj2.c and proj3.c do work
 pretty much raw from the PROJ_UNITS file. there is a lower() function in
 there, but I am not confident that it covers all bases. Probably want a
 double fix at both ends if possible.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/842#comment:19>
