[GRASS-dev] WinGrass-Installer - definition of the destination
folder?
Glynn Clements
glynn at gclements.plus.com
Sun Jan 17 20:35:40 EST 2010
Hamish wrote:
> > Grass64-Release => %ProgramFiles%\GRASS-64
> > Grass64-Dev => %ProgramFiles%\GRASS-64-SVN
> > We *need* this to work. If GRASS can't handle being
> > installed in %ProgramFiles%, that's a blocker, IMHO.
> It could be that this is a 6.4.0-final blocker, but //please// let's
> hold off on r40496 and release 6.4.0rc6 before beginning to validate
> that $GISBASE is space-safe.
If not now, then when? We need at least one RC which installs into
%ProgramFiles% by default. If that isn't RC6, then we will need an RC7
even if RC6 appears to work perfectly, and if it turns out that there
*are* problems with RC7, then we would need an RC8 to test the fixes.
> AFAIK there are no more major RC-blockers left & we are ready to go
> for rc6 -right now-.
Fine. Then release RC6 -right now-, with the default installation
directory as %ProgramFiles%\GRASS-64-RC6.
> If we start on the next thing it's going to be
> another 3 weeks+ before we can even think about shipping rc6. !@$%!#
> It resets the release confidence cycle.
At the risk of stating the obvious, a "release candidate" (as opposed
to a "beta") is ... a candidate for release. If no bugs are found,
then the RC gets released as the "release", with the only change being
that it's called "6.4.0" rather than "6.4.0-RC<something>".
If you know for a fact that the "RC" won't actually become the
release, even if no (significant) bugs are found, then it *isn't* a
"release candidate".
