[GRASS-dev] winGRASS compilation: perl not found (needed for MAN)
Markus Neteler neteler at osgeo.org
Tue Jan 19 01:30:26 EST 2010
On Tue, Jan 19, 2010 at 7:20 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> we try to compile winGRASS on a colleague's computer (XP),
>> following
>> https://trac.osgeo.org/grass/wiki/CompileOnWindows
>> ./mswindows/osgeo4w/package.sh
>> checking for perl... no
>> At this point, MAN is not created, leading to a tar packaging error later.
>> But:
>> $ perl -v
>> This is perl., v5.10.1 built for MSWin32-x86-multi-thread
>> I am suprised that perl isn't detected by configure. Nothing
>> dramatic of course.
> No idea why; it's just an AC_PATH_PROG() check; nothing unusual about
> it.
>> Did any other winGRASS builder observe this problem?
> I've never noticed it, because man/Makefile silently skips building
> the manpages if Perl isn't present (I don't have it on Windows).
That's right but "tar" complains (read: warns) about the missing man
stuff later. Perhaps it has to be conditionalized upon perl presence
as well.
> Maybe we should use the Python version from 7.0? Many users will want
> Python anyhow, whereas Perl is only used for g.html2man.
Sounds good, we would get rid of a dependency.
> OTOH, how many Windows users will want nroff manpages?
Likely 0.001%. It was more for a potential breakage of the packaging
process.
Markus
