[GRASS-dev] winGRASS compilation: perl not found (needed for MAN)
Glynn Clements
glynn at gclements.plus.com
Tue Jan 19 06:19:29 EST 2010
Markus Neteler wrote:
> > I've never noticed it, because man/Makefile silently skips building
> > the manpages if Perl isn't present (I don't have it on Windows).
> That's right but "tar" complains (read: warns) about the missing man
> stuff later. Perhaps it has to be conditionalized upon perl presence
> as well.
It's better to test what's actually required (i.e. the presence of the
dist.<arch>/man directory).
> > Maybe we should use the Python version from 7.0? Many users will want
> > Python anyhow, whereas Perl is only used for g.html2man.
> Sounds good, we would get rid of a dependency.
g.html2man.py shouldn't have any actual dependencies of its own.
However, I did have to clean up quite a few files in 7.0 to get the
parser to accept them (it's an actual HTML parser, and not
particularly fault-tolerant; the Perl version is just regexp
search/replace, so it might fail but it won't complain).
> > OTOH, how many Windows users will want nroff manpages?
> Likely 0.001%. It was more for a potential breakage of the packaging
> process.
Then it's probably beter to just modify the packager.
