[GRASS-dev] New option in r.neighbors
Soeren Gebbert soerengebbert at googlemail.com
Tue Jan 19 03:02:54 EST 2010
Hi Glynn,
2010/1/19 Glynn Clements <glynn at gclements.plus.com>:
> Soeren Gebbert wrote:
>> JFYI: i have added a new option "selection" to r.neighbors.
> A few points about the change:
> 1. Human-readable strings (option descriptions, messages) should be
> localised with _(...).
Sorry, i will check other modules, which i modified, to make sure i did
not forget the localization.
> 2. There's no need to read the map using its native type
> (CELL/FCELL/DCELL); reading as DCELL will suffice, and requires less
Ok.
> code. Better still, as you only care whether or not cells are null,
> you can use Rast_get_null_value_row().
I see, i never used Rast_get_null_value_row() before, thanks for your advise.
> 3. It reads the input a second time (at its native type, then converts
> to DCELL) when the input row will already be in ncb.buf[ncb.dist] (as
> DCELL).
> 4. There are a couple of deviations from the GRASS formatting
> conventions (see tools/grass_indent.sh), specifically space between
> "if" and "(" and "else" on a separate line to a preceding closing
> brace.
I german we call the coding which i have done "verschlimmbessern",
translated into english this means "Trying to improve things but
actually make them worse."
> Please check r40541.
Code looks much better now, thanks.
Soeren
