[GRASS-dev] missing proj-parms.table in GRASS 7
Michael Barton
Michael.Barton at asu.edu
Tue Jan 19 10:13:46 EST 2010
Well, we need what is in this file to correctly create a full proj4 string. It's easy to change where the location manager looks for files, but they need to be built.
Specifically, the following files are read by the __readData method of the LocationWizard class to create the lists and dictionaries needed for the wizard.
proj-parms.table
datum.table
ellipse.table
proj-desc.table
Michael
On Jan 19, 2010, at 3:52 AM, Glynn Clements wrote:
> Michael Barton wrote:
>> i don't know if this is a bug or a 'feature'.
>> Recently, the location wizard stopped running in GRASS 7 because
>> proj-parms.table is missing from $GISBASE/etc. Here is the error.
>> IOError: [Errno 2] No such file or directory:
>> '/Applications/Grass/GRASS-7.0.app/Contents/MacOS/etc/proj-parms.table'
>> So does this mean there is a bug that is preventing this file from
>> getting created or copied to the correct spot in GRASS 7?
>> Or does it mean that proj-parms.table has been replaced with
>> something else and we need to change the location wizard to parse
>> the new file, whatever it is?
> proj-{desc,parms,units}.table are part of g.setproj. g.setproj isn't
> built in 7.0, as it's a terminal-based interactive program, so those
> files don't get installed. This has been the case for a long time; it
> isn't a recent change.
> The files could be moved to e.g. lib/proj.
> Glynn Clements <glynn at gclements.plus.com>
