[GRASS-dev] missing proj-parms.table in GRASS 7
Tue Jan 19 12:03:26 EST 2010
Michael Barton wrote:
> Well, we need what is in this file to correctly create a full proj4
> string. It's easy to change where the location manager looks for files,
> but they need to be built.
> Specifically, the following files are read by the __readData method of
> the LocationWizard class to create the lists and dictionaries needed for
> the wizard.
> proj-parms.table
> datum.table
> ellipse.table
> proj-desc.table
I've moved proj-*.table from g.setproj to lib/proj in r40557.
datum.table and ellipse.table are from lib/gis, and are already
installed.
