[GRASS-dev] winGRASS compilation: perl not found (needed for MAN)
Markus Neteler neteler at osgeo.org
Wed Jan 20 01:44:38 EST 2010
On Wed, Jan 20, 2010 at 6:15 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> IMHO, the main reason to stick with the Perl version isn't down to
> which language to make a required dependency, but the effort required
> to clean up the 6.x manpages.
If the Python version would be backported to 6.5, I could walk through the
HTML pages, fix them and backport the HTML bugfixes to 6.4. They should
be done in any case...
Markus
