[GRASS-dev] Re: [GRASS-windows] GUI with python scripts
Glynn Clements
glynn at gclements.plus.com
Fri Jan 22 10:17:38 EST 2010
Ned Horning wrote:
> This is the output from g.gisenv:
> > menuform.py: can't open file 'c:/Program': [Errno 2] No such file or
> directory
You'll have to either wait for a newer version or install GRASS into
e.g. C:\GRASS.
Someone seems to have read my comments about having the next release
candidate install into the %ProgramFiles% directory, and decided to go
one better and start installing the 6.4.0-SVN snapshots there.
This won't work until the recent changes to the G_spawn* functions
have been back-ported. The current 6.4.0 code is known not to work
with spaces in $GISBASE. 6.5 should work (although based upon recent
comments, MSys might need to be installed in C:\msys).
