[GRASS-dev] Re: [GRASS GIS] #882: i18n enabled winGRASS: properties
dialog not opening
Markus Neteler
neteler at osgeo.org
Fri Jan 22 19:14:57 EST 2010
On Fri, Jan 22, 2010 at 4:30 PM, GRASS GIS <trac at osgeo.org> wrote:
> #882: i18n enabled winGRASS: properties dialog not opening
> Comment (by glynn):
> That's not what I'm asking. Is the text in the <description> and <label>
> elements in the --interface-description output encoded in EUC-JP or in
> UTF-8? If it's EUC-JP, then the header should say encoding=EUC-JP. If it's
> in UTF-8, the header should say encoding=UTF-8.
Right. But how to find out? Maybe I don't see the obvious.
Markus
