[GRASS-dev] Re: [GRASS GIS] #882: i18n enabled winGRASS:
properties dialog not opening
Glynn Clements
glynn at gclements.plus.com
Fri Jan 22 23:10:29 EST 2010
Markus Neteler wrote:
> > #882: i18n enabled winGRASS: properties dialog not opening
> > Comment (by glynn):
> > That's not what I'm asking. Is the text in the <description> and <label>
> > elements in the --interface-description output encoded in EUC-JP or in
> > UTF-8? If it's EUC-JP, then the header should say encoding=EUC-JP. If it's
> > in UTF-8, the header should say encoding=UTF-8.
> Right. But how to find out? Maybe I don't see the obvious.
1.
r3.info --interface-description > desc.txt
[Pick any command which actually has Japanese translations.]
2.
iconv -f utf-8 -t utf-8 desc.txt >/dev/null
iconv -f euc-jp -t utf-8 desc.txt >/dev/null
One of these commands should work, the other should produce an
"illegal input sequence" error.
