[GRASS-dev] Re: [GRASS GIS] #885: WinGrass: displaying
r.external-linked raster data not working
trac at osgeo.org
Sun Jan 24 13:38:00 EST 2010
#885: WinGrass: displaying r.external-linked raster data not working
Reporter: hellik | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Display | Version: svn-releasebranch64
Resolution: | Keywords: r.external, WinGrass, osgeo4w
Platform: MSWindows Vista | Cpu: x86-32
Comment (by glynn):
Replying to [comment:17 hellik]:
> i've tested make GDAL_DYNAMIC= together with the patch for gdal.c,
r.external is working and d.rast map=!LinkedRaster is working in the wx-
gui.
> is "make GDAL_DYNAMIC=" maybe interfering with other things and should
this be turned on for Grass64?
The support for loading GDAL dynamically was added to prevent GDAL from
becoming a critical dependency. If GDAL is linked at compile time, any
linkage errors for GDAL would make GRASS entirely unusable.
And GDAL is a very heavy-weight dependency; on my system, libgdal.so has
32 dependencies, and that's with some of the less common formats disabled.
OTOH, given that programs such as g.region and g.proj require it, it's
essentially a critical dependency already.
Ticket URL: <https://trac.osgeo.org/grass/ticket/885#comment:18>
