[GRASS-dev] typo in r.out.gdal message: constains
Bruce Raup bruceraup at gmail.com
Mon Jan 25 18:03:06 EST 2010
Minor bit of feedback to the developers:  I think "constains" should
be "contains" in the following message from r.out.gdal (using version
6.3 of GRASS):
WARNING: Input raster map constains cells with NULL-value (no-data). The
         value -1 was used to represent no-data values in the input map.You
         can specify nodata value by nodata parameter.
Also, there's no space between the two sentences.
Cheers,
Bruce
Bruce Raup
http://cires.colorado.edu/~braup/
