[GRASS-dev] typo in r.out.gdal message: constains
Markus Neteler
neteler at osgeo.org
Mon Jan 25 20:20:07 EST 2010
On Tue, Jan 26, 2010 at 12:03 AM, Bruce Raup <bruceraup at gmail.com> wrote:
> Minor bit of feedback to the developers: I think "constains" should
> be "contains" in the following message from r.out.gdal (using version
> 6.3 of GRASS):
> WARNING: Input raster map constains cells with NULL-value (no-data). The
> value -1 was used to represent no-data values in the input map.You
> can specify nodata value by nodata parameter.
> Also, there's no space between the two sentences.
Thanks, Bruce, fixed in SVN.
It more recent versions (>= 6.4) it was already corrected.
Markus
