[GRASS-dev] Scripting in Linux
Kim Besson kimbesson1981 at gmail.com
Tue Jan 26 05:17:59 EST 2010
Thanks. But regarding other scripts (r.*, v.*) I just have to add them to
the Scripts folder  without doing anything else,right? (because in Windows
it's necessary to run make)
Regarding "add it with the "command layer" button." what do you mean with
this? Do add a button in Wxpython GUI menu (menudata.xml)?
Thanks
Kim
2010/1/26 Hamish <hamish_b at yahoo.com>
> Kim wrote:
> > I'm having a few Questions regarding
> > Scripting developing and compilation for LINUX. I have
> > "coded" a Script example, from GRASS book, and now
> > I just want to try it. But it says "Command
> > d.rast.region is not yet implemented". Do I have to do
> > something because it's already in the right
> > folder /usr/local/grass-6.4.0svn/scripts.
> add it with the "command layer" button. most d.* modules can not
> control the GUI display window directly.
> (but can from the terminal command line on UNIX/X11 with d.mon)
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100126/51bd7d96/attachment.html
