[GRASS-dev] Scripting in Linux
Hamish hamish_b at yahoo.com
Tue Jan 26 06:23:37 EST 2010
Kim wrote:
> Thanks. But regarding other scripts (r.*,
> v.*) I just have to add them to the
> Scripts folder  without doing anything else,right?
sure, as long as they have their executable bit set and are in
the search path.
FWIW, I try to copy custom stuff into a dir outside the install
dir which is pointed to by the GRASS_ADDON_PATH environment
variable, that way I can replace & upgrade grass versions
without accidentally deleting all my custom scripts.
see the "variables" help page.
> (because in Windows it's necessary to run make)
I'm not really familiar with adding scripts on Windows, sorry.
> Regarding "add it with the "command layer" button." what do
> you mean with this?
In the (wx)GIS Layer Manager window theres a button for it with
what looks like a tiny prompt (>_) just to the left of one
with a paperclip. In the TclTk GUI the button looks like a cross
between a cog and a flower.
Hamish
