[GRASS-dev] Re: List of new features in GRASS 7 (in trac)
Soeren Gebbert soerengebbert at googlemail.com
Tue Jan 26 09:44:53 EST 2010
Hello Markus,
new IMHO noticeable features in GRASS 7 are:
gmath:
* Replacement of most of the numerical recipes code with ccmtah
functionality (lu solver is work in progress)
* Implementation of blas level 1,2 and 3 functions which are in use by
all gmath solver, the gpde library and many modules.
* ATLAS wrapper for blas level 1 functions (level 2, and 3 are work in progress)
raster:
r.neighbours -> added new option to process only marked cells (i.e:
selective elevation map improvement)
r(3).gwflow -> Added support for water budget calculation,
documentation largely improved
r.solute.transport -> New module to compute the solute transport of
groundwater in porous media using an implicit finite volume approach
imagery:
i.cca -> supports now much more raster maps for canonical analyses
(multi-spectral (8) -> hyper-spectral (thousands)),  converted from
Fortran style to C-style :)
Just my 2c
Soeren
2010/1/26 Markus Neteler <neteler at osgeo.org>:
> On Mon, Jan 25, 2010 at 11:17 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> Hi,
>> I have started the draft list of new features in GRASS 7:
>> http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures
>> This will help to better advertise our progress. Please add
>> missing items (there will be many).
> I'll give a talk in 23hs from now - please tell me about things
> missing in the features list :) You can also just respond here
> and I'll update the Wiki.
> Just to avoid that central improvements are not mentioned.
> cheers
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
