[GRASS-dev] Re: List of new features in GRASS 7 (in trac)
Soeren Gebbert soerengebbert at googlemail.com
Tue Jan 26 09:54:03 EST 2010
Hello,
sorry for the noise, i forgot to mention:
I have ported r.sim.water and r.sim.sediment to be functional in grass
7, but they are still
not compiled by default. Vector point support is still missing, the
old "site" code is only commented out.
Much more testing is needed.
WPS:
libgis supports the automatic generation of a WPS 1.0.0 process
description XML document for each module (c, c++, python, shell)
Best regards
Soeren
2010/1/26 Markus Neteler <neteler at osgeo.org>:
> On Mon, Jan 25, 2010 at 11:17 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> Hi,
>> I have started the draft list of new features in GRASS 7:
>> http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures
>> This will help to better advertise our progress. Please add
>> missing items (there will be many).
> I'll give a talk in 23hs from now - please tell me about things
> missing in the features list :) You can also just respond here
> and I'll update the Wiki.
> Just to avoid that central improvements are not mentioned.
> cheers
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
