[GRASS-dev] Re: List of new features in GRASS 7 (in trac)
Glynn Clements
glynn at gclements.plus.com
Tue Jan 26 15:02:12 EST 2010
Soeren Gebbert wrote:
> I have ported r.sim.water and r.sim.sediment to be functional in grass
> 7, but they are still
> not compiled by default. Vector point support is still missing, the
> old "site" code is only commented out.
> Much more testing is needed.
If you suspect that they'll compile on most systems, I'd suggest
enabling them.
Given the frequency of library changes in 7.0, any code which is
disabled will be prone to bit-rot, i.e. not being updated to account
for library changes.
