[GRASS-dev] Scripting in Linux
Tue Jan 26 15:24:34 EST 2010
Kim Besson wrote:
> And at the command output it was:
> <?xml version="1.0" encoding="ANSI_X3.4-1968"?>
> <!DOCTYPE task SYSTEM "grass-interface.dtd">
> <task name="i.ndvi">
[snip]
I don't see anything wrong with that.
Does your script work from the command line? Does it work when run
with the --ui switch?
