[GRASS-dev] Scripting in Linux
Kim Besson kimbesson1981 at gmail.com
Wed Jan 27 05:16:44 EST 2010
Hello Clements
Ok. I have tested what Antonio sent to the mailing list and the problem is
that one: I used special characters in the Module/Option description.
So, it seems that I cannot use those special characters.
My question is: If I want to add a text line in *.po files, regarding a
description in a Script, in wich *.po file I have to add an extra line?
And how can I tell if it's a UTF-8 or a ISO-8859-* file?
Thank you so much
Kim
2010/1/26 Glynn Clements <glynn at gclements.plus.com>
> Kim Besson wrote:
> > And at the command output it was:
> > <?xml version="1.0" encoding="ANSI_X3.4-1968"?>
> > <!DOCTYPE task SYSTEM "grass-interface.dtd">
> > <task name="i.ndvi">
> [snip]
> I don't see anything wrong with that.
> Does your script work from the command line? Does it work when run
> with the --ui switch?
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100127/2ed3b357/attachment.html
