[GRASS-dev] Compiling i.pr
Luisa Peña
luisapena1979 at gmail.com
Thu Jan 28 12:55:20 EST 2010
Hello Markus
That is weird because in December2009 GRASS mailing list Archive are a few
messages, from Glynn Clements, explaining/debugging i.pr compilation in
WinGRASS 6.4 and it worked. Back at that that time the problems were a
library and drand48 (that doesn't exist in Windows). So the problem might be
other...
Several o i.pr.X are compiled but, as far as I can see, only i.pr is not
there.
The following errors seems to have something to do with vector support:
/usr/local/grass-6.4.0svn/include/grass/vect/dig_structs.h:179: error:
expected specifier-qualifier-list before ‘OGRDataSourceH’
/usr/local/grass-6.4.0svn/include/grass/vect/dig_structs.h:22:21: error:
ogr_api.h: No such file or directory
Any idea? (This classification module one of the main modules for me to
choose GRASS and I saw it working on WinGRASS and it's pretty COOL).
Thank you for your help
Luisa
2010/1/28 Markus Neteler <neteler at osgeo.org>
> On Thu, Jan 28, 2010 at 12:36 PM, Luisa Peña <luisapena1979 at gmail.com>
> wrote:
> > Greetings all
> > After I install laters Svn6.4.0 version, r.example and v.example (just
> for
> > test) I decided to compile i.pr (an add-on for GRASS available at grass
> > website).
> > Unfortunely I got a few errors, that I thought were minor but, after all,
> > i.pr is not working...
> > And those are:
> > (2 times)
> > sh: Can't open /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man
> > make[3]: *** [/usr/local/grass-6.4.0svn/man/man1/i.pr.model.1] Error 2
> > (2 times)
> > ERROR: G_getenv(): Variable LOCATION_NAME not set
> > and once:
> > Does anyone knows what might be the problem? or maybe what configuration
> > parameter am I missing?
> Hi Luisa,
> i.pr was written by my former colleague for an older version of GRASS
> (6.1 if I recall correctly). Some code update will be needed and
> appreciated.
> Currently the module set lacks a maintainer but it is outstanding in
> functionality.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100128/2b4d2fad/attachment.html
