Fwd: [GRASS-dev] Scripting in Linux
Kim Besson
kimbesson1981 at gmail.com
Fri Jan 29 04:30:07 EST 2010
Ok I try that command and nothing seems to happen.
Then I tried GRASS with DE language package and only wxGUI was translated.
What am I missing? Because it should be just fine... Or what should I have
to do to debug this issue?
2010/1/29 Glynn Clements <glynn at gclements.plus.com>
> Kim Besson wrote:
> > Ok Regarding this email, according to an email from Glynn, I sould have
> this
> > folder /usr/share/i18n/locales in order to run Language packages.
> > But I do have... Any thoughts about this?
> You may also need to compile them (some distributions compile all
> locales automatically, others require that specific locales are
> enabled). Try "localedef --list-archive".
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100129/4e7e151e/attachment.html
