Fwd: [GRASS-dev] Scripting in Linux
Fri Jan 29 09:36:17 EST 2010
Kim Besson wrote:
> Ok I try that command and nothing seems to happen.
> Then I tried GRASS with DE language package and only wxGUI was translated.
This normally indicates that GRASS was built without NLS.
> What am I missing? Because it should be just fine...  Or what should I have
> to do to debug this issue?
1. Are you sure that NLS is enabled? I mention this because configure
silently ignores unknown (e.g. mis-spelled) configure switches.
Check for:
	#i18N
	HAVE_NLS            = 1
in Platform.make and :
	/* define if libintl.h exists */
	#define HAVE_LIBINTL_H 1
	/* define if iconv.h exists */
	#define HAVE_ICONV_H 1
	/* define if NLS requested */
	#define USE_NLS 1
in config.h.
Also check for:
         U bindtextdomain
and:
         U dgettext
in the output from:
	nm -D dist.i686-pc-linux-gnu/lib/libgrass_gis.so
and:
         U G_gettext
in the output from:
	nm -D dist.i686-pc-linux-gnu/bin/g.parser
2. Have you re-created the .mo file after modifying the .po file? This
is done with:
	make -C locale mo
