[GRASS-dev] Re: [GRASS GIS] #1101: WinGrass7 + scripts are not found in the command line
GRASS GIS trac at osgeo.org
Fri Jul 2 03:43:22 EDT 2010
 Reporter:  hellik             |       Owner:  grass-dev@…
     Type:  defect             |      Status:  new
 Priority:  normal             |   Milestone:  7.0.0
Component:  Packaging          |     Version:  svn-trunk
 Keywords:  wingrass, scripts  |    Platform:  MSWindows Vista
      Cpu:  Unspecified        |
Comment(by glynn):
 Replying to [ticket:1101 hellik]:
 GRASS 7.0.svn> g.manual
 sh.exe": g.manual: command not found
 Check the setting of `%GRASS_SH%`.
 It should be set with something like:
 set GRASS_SH=C:\msys\1.0\bin\sh.exe
 or:
 set GRASS_SH=C:\Program Files\GRASS-70-SVN\msys\1.0\bin\sh.exe
 There shouldn't be any quotes, even if the filename contains spaces.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1101#comment:5>
