[GRASS-dev] Maximum safe map name size?
Joel Pitt
joel.pitt at gmail.com
Tue Jul 6 00:17:46 EDT 2010
On Sun, Jul 4, 2010 at 5:48 PM, Hamish <hamish_b at yahoo.com> wrote:
>> Hamish wrote:
>> > as you found, on top of that, grass 6 titles (cats+hist) are
>> > going to be limited to RECORD_LEN chars. an update of the meta-
>> > data backend remains a major TODO for grass 7.
> Glynn:
>> FWIW, I've re-written this in r42695.
>> The fields of "struct History" are now dynamically allocated, rather
>> than fixed-size arrays, so RECORD_LEN and MAXEDLINES no longer exist.
>> Also, set/get functions are provided, eliminating the need
>> to access the structure fields directly.
>> Code which simply truncated strings to RECORD_LEN now stores the
>> complete string. Code which breaks long strings into
>> multiple lines has been preserved.
> as always, bloody excellent.
> does anyone know/is involved with an OSGeo-wide library/project to deal
> with the EU's INSPIRE metadata needs etc? (I'd really rather not attempt
> to maintain our own fork of such a thing)
> [e.g. something with GeoNetwork http://www.osgeo.org/geonetwork]
Thanks Hamish for the explanation and the reference to where in the
code the limits are (were) kept.
Thanks Glynn for the move to to dynamically allocated history fields.
In answer to the length of the filenames I was using... they were too
long generally and I realised that I could avoid them. I was storing
model outputs which included parameters, time step, model names etc to
differentiate. Now I use separate mapsets for each specific
combination of parameters and just use a subdirectory in the mapset
for storing model metadata/analysis.
edit: I just looked up some model logs where I was having the issue
and the files causing the problems were 155 char long in a mapset 24
chars long.
J
