[GRASS-dev] Error launching wxgui
Eric Patton epatton at nrcan.gc.ca
Wed Jul 7 09:30:36 EDT 2010
I've encountered the following error launching the wxgui from Grass 6.5
using today's svn checkout:
(I get several screens worth of the following text)
<snip>
d': None}, 'boundaryOne': {'color': (0, 255, 0), 'enabled': True}, 'direction': {'color': (255, 0, 0), 'enabled': False}, 'point': {'color': (0, 0, 0), 'enabled': True}, 'area': {'color': (217, 255, 217), 'enabled': False}, 'vertex': {'color': (255, 20, 147), 'enabled': False}, 'boundaryNo': {'color': (126, 126, 126), 'enabled': True}, 'highlight': {'color': (255, 255, 0), 'enabled': None}, 'centroidOut': {'color': (165, 42, 42), 'enabled': True}, 'centroidIn': {'color': (0, 0, 255), 'enabled': True}, 'centroidDup': {'color': (156, 62, 206), 'enabled': True}, 'nodeTwo': {'color': (0, 86, 45), 'enabled': True}, 'nodeOne': {'color': (255, 0, 0), 'enabled': True}, 'boundaryTwo': {'color': (255, 135, 0), 'enabled': True}, 'line': {'color': (0, 0, 0), 'enabled': True}}, 'queryDangle': {'than-selection': 0, 'thresh': 0}, 'catBoundary': {'enabled': False}}, 'workspace': {'posManager': {'enabled': False}, 'posDisplay': {'enabled': False}}, 'modeler': {'action': {'color': {'disabled': (211, 211, 211, 255), 'running': (255, 0, 0), 'valid': (211, 211, 211), 'invalid': (255, 255, 255)}, 'width': {'default': 1, 'parameterized': 2}, 'size': {'width': 100, 'height': 50}}, 'data': {'color': {'raster': (215, 215, 248), 'vector': (248, 215, 215), 'raster3d': (215, 248, 215)}, 'size': {'width': 175, 'height': 50}}, 'loop': {'size': {'width': 175, 'height': 50}}}, 'advanced': {'iconTheme': {'type': 'grass'}, 'settingsFile': {'type': 'home'}}}
advanced settingsFile type home
<snip>
After all this finishes, the following message is printed:
WARNING: Nviz extension (3D view mode) disabled. Reason: No module named ogsf
  File "/usr/local/grass-6.5.svn/etc/wxpython/wxgui.py", line 85, in <module>
    import gui_modules.nviz_tools as nviz_tools
  File "/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/nviz_tools.py", line 2861, in <module>
    class NvizPreferencesDialog(PreferencesBaseDialog):
NameError: name 'PreferencesBaseDialog' is not defined
~ Eric.
