[GRASS-dev] Re: [GRASS-user] Error launching wxgui
Markus Metz
markus.metz.giswork at googlemail.com
Thu Jul 8 02:32:24 EDT 2010
Eric Patton wrote:
> Hi,
> I've encountered the following error launching the wxgui from Grass 6.5
> using today's svn checkout:
> (I get several screens worth of the following text)
Looks like Martin Landa is printing out the settings for debugging?
There is new print stuff as of r42689 in preferences.py
The Nviz warning should go away soon, Martin is busy with it for GSoC.
> <snip>
> d': None}, 'boundaryOne': {'color': (0, 255, 0), 'enabled': True}, 'direction': {'color': (255, 0, 0), 'enabled': False}, 'point': {'color': (0, 0, 0), 'enabled': True}, 'area': {'color': (217, 255, 217), 'enabled': False}, 'vertex': {'color': (255, 20, 147), 'enabled': False}, 'boundaryNo': {'color': (126, 126, 126), 'enabled': True}, 'highlight': {'color': (255, 255, 0), 'enabled': None}, 'centroidOut': {'color': (165, 42, 42), 'enabled': True}, 'centroidIn': {'color': (0, 0, 255), 'enabled': True}, 'centroidDup': {'color': (156, 62, 206), 'enabled': True}, 'nodeTwo': {'color': (0, 86, 45), 'enabled': True}, 'nodeOne': {'color': (255, 0, 0), 'enabled': True}, 'boundaryTwo': {'color': (255, 135, 0), 'enabled': True}, 'line': {'color': (0, 0, 0), 'enabled': True}}, 'queryDangle': {'than-selection': 0, 'thresh': 0}, 'catBoundary': {'enabled': False}}, 'workspace': {'posManager': {'enabled': False}, 'posDisplay': {'enabled': False}}, 'modeler': {'action': {'color': {'disabled': (211, 211, 211, 255), 'running': (255, 0, 0), 'valid': (211, 211, 211), 'invalid': (255, 255, 255)}, 'width': {'default': 1, 'parameterized': 2}, 'size': {'width': 100, 'height': 50}}, 'data': {'color': {'raster': (215, 215, 248), 'vector': (248, 215, 215), 'raster3d': (215, 248, 215)}, 'size': {'width': 175, 'height': 50}}, 'loop': {'size': {'width': 175, 'height': 50}}}, 'advanced': {'iconTheme': {'type': 'grass'}, 'settingsFile': {'type': 'home'}}}
> advanced settingsFile type home
> <snip>
> After all this finishes, the following message is printed:
> WARNING: Nviz extension (3D view mode) disabled. Reason: No module named ogsf
> Traceback (most recent call last):
> File "/usr/local/grass-6.5.svn/etc/wxpython/wxgui.py", line 85, in <module>
> import gui_modules.nviz_tools as nviz_tools
> File "/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/nviz_tools.py", line 2861, in <module>
> class NvizPreferencesDialog(PreferencesBaseDialog):
> NameError: name 'PreferencesBaseDialog' is not defined
> ~ Eric.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
