[GRASS-dev] Re: [GRASS GIS] #1006: r.terraflow fails to stat()
stream file on Windows
trac at osgeo.org
Thu Jul 8 03:41:33 EDT 2010
#1006: r.terraflow fails to stat() stream file on Windows
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.1
Component: Raster | Version: svn-releasebranch64
Keywords: wingrass, r.terraflow | Platform: MSWindows Vista
Cpu: x86-32 |
Changes (by mmetz):
* priority: critical => major
* milestone: 6.4.0 => 6.4.1
Comment:
Replying to [comment:30 marisn]:
> Tested with WinGRASS-6.4.SVN-r42668-1 on Vista. It's better now, as in
CLI it fails with same message as in wxGUI (stats.out: Permission denied).
No more assertion errors. Horray! Still r.terraflow is not working for
windows users.
Still getting the same assertion error on 6.4 r42714:
Assertion failed: nrows * ncols == str->stream_len(), file
grass2str.h, line 144
About stats.out: Permission denied, stats.out is not written to STREAM_DIR
because everything in STREAM_DIR is deleted after successful completion,
stats.out is written to the current working directory and remains there
for inspection. On my test Windows system, the current directory is
/c/Dokumente und Einstellungen/Markus and I can write to it.
r.terraflow is on windows crippled by missing LFS in GRASS. Its strength
is its performance with massive datasets, but these can't be processed on
windows because of the 2GB file size limit. Grass with LFS on windows will
likely only be available in grass 7, planned for next month, but not in
grass 6. r.terraflow is working fine on Linux and its functionality is
covered by other modules, therefore it is IMHO not critical to have a
working r.terraflow on windows. It would be very nice though.
Considering this as well as previous comments, I think it's more realistic
to get it fixed in 6.4.1 or 6.5, but under windows it will be really
useful only in grass 7.0 with LFS.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1006#comment:31>
