[GRASS-dev] Re: [GRASS GIS] #1006: r.terraflow fails to stat()
stream file on Windows
trac at osgeo.org
Thu Jul 8 05:31:36 EDT 2010
#1006: r.terraflow fails to stat() stream file on Windows
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Raster | Version: svn-releasebranch64
Keywords: wingrass, r.terraflow | Platform: MSWindows Vista
Cpu: x86-32 |
Changes (by hamish):
* priority: major => critical
* milestone: 6.4.1 => 6.4.0
Comment:
putting this back on the table for 6.4.0, without hesitation. see plan in
comment:27.
I don't think we are far off having this working -- it may be working in
6.5 already and just need a backport.
r.terraflow (and v.buffer) are flagship modules for GRASS and frankly it's
an embarrassment not to have them working properly (even if their full
glory is crippled as in the case of LFS + r.terraflow).
Markus Metz wrote:
> Still getting the same assertion error on 6.4 r42714:
well, yes, because the stat() work-around has not been backported to the
6.4 branch pending testing in 6.5. Please test it in 6.5 (run from a dir
with write permissions :). I hope that stats.out error is not fatal to the
process.
regards,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1006#comment:32>
