[GRASS-dev] Re: [GRASS GIS] #1006: r.terraflow fails to stat()
stream file on Windows
trac at osgeo.org
Mon Jul 12 13:35:30 EDT 2010
#1006: r.terraflow fails to stat() stream file on Windows
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Raster | Version: svn-releasebranch64
Keywords: wingrass, r.terraflow | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by glynn):
Replying to [comment:52 mmetz]:
> stream_len itself is called very often
In which case, it shouldn't be calling stat() either. This isn't exactly
fast on Unix, is quite slow on Windows, and is extremely slow on Cygwin.
On Unix, fstat() is typically significantly faster than stat(), as stat()
needs to resolve the pathname to an inode, which requires lookups and
permission checks on each component in the path.
However: both fstat() and stat() reflect the size of the underlying file,
which isn't necessarily the same as the size of the stream (FILE*) if
buffering is in use. The only reliable way to determine the size of a
stream is fseek(SEEK_END)+ftell().
If stream_len() is called often, it would be better to make the AMI_STREAM
class keep track of its own length, updating it in the write_item() and
write_array() methods.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1006#comment:53>
