[GRASS-dev] GRASS Imagery
Markus Metz
markus.metz.giswork at googlemail.com
Thu Jul 15 11:42:06 EDT 2010
Hamish wrote:
> just a quick wish, could the right panel hide away with a triangle
> button, like in tcltk NVIZ in the bottom-left to hide the control
> panel.
Different solution: if no target map is specified for display, the
target display is hidden. A map can be added later on to the target
display through the settings dialog which will make the target display
visible.
> often you are just working with a single scanned map with known
> GPS coords.
Right.
> also fyi lat/lon (+D:M:S) support was a cause of a number of old
> i.points bugs. mostly due to the programmer not thinking about
> that. (losing fidelity with %f, not accepting D:M:S etc)
There is a utility to convert DMS to decimal degrees, I could use that.
Markus M
