[GRASS-dev] GRASS Imagery
Hamish
hamish_b at yahoo.com
Fri Jul 16 01:20:01 EDT 2010
Hamish wrote:
> > just a quick wish, could the right panel hide away with a triangle
> > button, like in tcltk NVIZ in the bottom-left to hide the control
> > panel.
Markus Metz wrote:
> Different solution: if no target map is specified for display, the
> target display is hidden. A map can be added later on to the target
> display through the settings dialog which will make the target display
> visible.
yes, that's even better.
> There is a utility to convert DMS to decimal degrees, I could use that.
float_or_dms(string) in lib/python/core.py
(funny name; still needs S,W suffix to negative value? beware scanning
floats ending with "E" are not actually 1e+6 [more for when importing
model output from a file])
cheers,
Hamish
