[GRASS-dev] Re: [GRASS GIS] #917: v.digit map creation weirdness on
wingrass
trac at osgeo.org
Sun Jul 18 14:32:36 EDT 2010
#917: v.digit map creation weirdness on wingrass
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: svn-releasebranch64
Keywords: wingrass, v.digit | Platform: MSWindows XP
Cpu: x86-32 |
Changes (by mmetz):
* priority: major => normal
Comment:
Replying to [comment:1 hamish]:
> see discussion and DEBUG log in the second half of #843.
> it seems to be losing contents of &Map by the time it gets to end() in
centre.c.
It gets there twice, the second time the vector has already been closed
and is no longer available:
Excerpt from #843 comment:31
Replying to [comment:31 marisn]:
[snip]
D3/3: c_update_tool()
D3/3: c_next_tool()
D2/3: Tool_next = 1
D2/3: Quit
D1/3: end()
[snip]
Building topology for vector map <bar>...
[snip]
D1/3: Vect_close(): name = bar, mapset = user1, format = 0, level = 2
[snip]
Region restored to original extent.
D3/3: c_next_tool()
D2/3: Tool_next = 1
D2/3: Quit
D1/3: end()
[snip]
Building topology for vector map <(null)>...
D1/3: Vect_close(): name = (null), mapset = (null), format = 0, level = 1
A bit annoying, but there is no report that the changes have not been
saved, IOW, the module produces results as expected. Downgrading priority.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/917#comment:4>
