[GRASS-dev] [GRASS GIS] #1110: v.rast.stats locks up on wingrass
GRASS GIS trac at osgeo.org
Mon Jul 19 09:10:32 EDT 2010
 Reporter:  hamish                                       |       Owner:  grass-dev@…
     Type:  defect                                       |      Status:  new
 Priority:  normal                                       |   Milestone:  6.4.0
Component:  Vector                                       |     Version:  svn-releasebranch64
 Keywords:  wingrass, v.rast.stats, v.db.addcol, v.info  |    Platform:  MSWindows XP
      Cpu:  x86-32                                       |
 Hi, as reported on the ML:
  http://thread.gmane.org/gmane.comp.gis.grass.user/36116/
 the shell script version of v.rast.stats gets stuck on WinGrass.
 for me using XP from the msys rxvt command prompt it works about 50% of
 the time. Sometimes there was a left over v.info.exe in the ctrl-alt-del
 process list, sometimes a db.describe. Adding -x to the shebang only helps
 as far as g.parser. I've now added some new debug messages in 6.5svn,
 maybe they help determine if it is before or in v.db.addcol ?
 ^C does not seem to work in the msys rxvt bash session so to kill it I had
 to either kill grass or kill the hung process in the ctrl-alt-del process
 list at which point the script bailed out.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1110>
