[GRASS-dev] Re: [GRASS GIS] #930: Wingrass7 - compiling errors
trac at osgeo.org
Mon Jul 19 16:29:00 EDT 2010
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Keywords: wingrass, grass7 | Platform: MSWindows Vista
Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:6 glynn]:
> Replying to [comment:5 hellik]:
> > tested with rev 41474, gem still fails compiling.
> Even if the compile errors were fixed, it wouldn't run. There are lots
of Unix-isms, e.g. hard-coded /tmp, system() with Unix-specific commands
(Windows' system uses cmd.exe), etc.
> Making it work with Windows would probably require a complete re-write
(and for what GEM does, it should probably be written in Python anyhow),
so I'll remove it from 7.0.
the compiling errors are fixed for wingrass7, gem is removed in grass7 and
grass7 is compiling now on windows in the osgeo4w-stack.
so I will close the ticket.
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/930#comment:7>
