[GRASS-dev] Re: [GRASS GIS] #606: WinGRASS GIS.m: broken newlines in output window
GRASS GIS trac at osgeo.org
Mon Jul 19 17:18:45 EDT 2010
 Reporter:  hamish          |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  major           |   Milestone:  6.4.0
Component:  Tcl             |     Version:  6.4.0 RCs
 Keywords:  wingrass gis.m  |    Platform:  MSWindows XP
      Cpu:  x86-32          |
Comment(by hellik):
 Replying to [ticket:606 hamish]:
 > Hi,
 > in wingrass gis.m output the leading newlines seem to be broken. When
 you run a command the first couple of letters seem to be hidden. When you
 resize the Output window by dragging on the corner (or if you run another
 command) the first missing letter appears next to the scissors icon, and
 the second missing letter appears at the start of the next line.
 > see attached screenshot.
 > I assume it is because gtcltk/gronsole.tcl hardcodes "\n" in a number of
 places (e.g. line 231) which needs to be "\r\n" on wingrass.
 > maybe something like this at the beginning of gronsole.tcl?
 > if { $mingw == "1" } {
 >    set newline "\r\n"
 > } else {
 >    set newline "\n"
 > and then use $newline instead of "\n"?
 > Hamish
 tested with WinGRASS-6.4.SVN-r42833-1-Setup.exe in a WinVista32-box.
 it's still valid.
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/606#comment:6>
