[GRASS-dev] Re: [GRASS GIS] #1020: Display of vector maps fails
trac at osgeo.org
Mon Jul 19 17:22:17 EDT 2010
Reporter: MilenaN | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: Database | Version: 6.4.0 RCs
Keywords: wingrass, db.describe, wxGUI | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by crazyb0b):
Replying to [comment:23 martinl]:
> Please provide more precise description...
> Martin
Most of the time the GUI just freezes up with the selection box in the
clicked position. Other times I receive this message:
The program 'python' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadRequest (invalid request code or no such operation)'.
(Details: serial 2659954 error_code 1 request_code 121 minor_code 0)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error()
function.)
> Can you reproduce this behaviour also with GRASS 6.4?
I've been using the TCLTK GUI in 6.4 and that seems to work just fine.
I'll try later with the wxPython GUI and see if the same issue occurs.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1020#comment:24>
