[GRASS-dev] Error building Grass6 devel branch on Ubuntu due to nviz
Tim Michelsen
timmichelsen at gmx-topmail.de
Wed Jul 21 17:57:35 EDT 2010
Hello,
please help me with the following make error:
build_html_index.sh
Generating HTML manual pages index (help system)...
Generated HTML docs in ../dist.i686-pc-linux-gnu/docs/html/index.html
Following modules are missing the 'description.html' file in src code:
GRASS GIS compilation log
Started compilation: Mi 21. Jul 23:49:43 CEST 2010
Errors in:
/usr/local/src/checkouts/grass/grass6_devel/gui/wxpython/nviz
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Mi 21. Jul 23:52:25 CEST 2010
make: *** [default] Fehler 1
Thanks,
Timmie
