[GRASS-dev] Error building Grass6 devel branch on Ubuntu due to
nviz
Moskovitz, Bob
Bob.Moskovitz at conservation.ca.gov
Wed Jul 21 18:06:32 EDT 2010
I got the same error. It would be great if I can get nviz to work
again. -Bob
-----Original Message-----
[mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Tim Michelsen
Sent: Wednesday, July 21, 2010 2:58 PM
To: grass-dev at lists.osgeo.org
Subject: [GRASS-dev] Error building Grass6 devel branch on Ubuntu due to
nviz
Hello,
please help me with the following make error:
build_html_index.sh
Generating HTML manual pages index (help system)...
Generated HTML docs in ../dist.i686-pc-linux-gnu/docs/html/index.html
Following modules are missing the 'description.html' file in src code:
GRASS GIS compilation log
Started compilation: Mi 21. Jul 23:49:43 CEST 2010
Errors in:
/usr/local/src/checkouts/grass/grass6_devel/gui/wxpython/nviz
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you
will
also get errors from anything which uses the library.
Finished compilation: Mi 21. Jul 23:52:25 CEST 2010
make: *** [default] Fehler 1
Thanks,
Timmie
grass-dev mailing list
http://lists.osgeo.org/mailman/listinfo/grass-dev
