[GRASS-dev] 6.4.0 blocker bugs
Markus Neteler
neteler at osgeo.org
Mon Jul 26 15:15:31 EDT 2010
On Tue, Jul 6, 2010 at 10:07 PM, Markus Metz
<markus.metz.giswork at googlemail.com> wrote:
> Hamish wrote:
> [snip]
>> RC bugs according to the trac'er:
>> https://trac.osgeo.org/grass/report/13
> The one blocker applies to Windows 7 only. My point was that for Linux
> and IIUC also MAC 6.4 is stable. GRASS is not part of a Windows7
> installation, but available through Linux repositories, e.g. yum
> install grass should give you 6.4 without enabling particular
> repositories, GDAL and PROJ4, also QGIS and SAGA are available through
> standard repositories. Nothing but man power keeps us from making
> available new wingrass installers on a regular basis.
the two (!) remaining blocker bugs are:
* https://trac.osgeo.org/grass/ticket/1115
-> Mac OSX only? Seems to be a wxpython 2.8.10.1 problem (wasn't there
something similar recently in the new i.points?)
* https://trac.osgeo.org/grass/ticket/1020
-> Windows. AFAIK solved and spammed with another problem.
>> I'm still meaning to spend a little time on this:
>> #1051 wxgui: SEARCH_PATH corruption
> Great!
Please do or postpone - we are holding 9000 or so changes
after the last stable release. And 6.4.1 will come out way
faster.
>> and verify that g.proj's memory bug is /really/ fixed:
>> https://trac.osgeo.org/grass/ticket/1032
> A mystery because not reproducible.
-> was closed.
>> https://trac.osgeo.org/grass/ticket/827
> Windows only, out of reach for us, unless we make a plan on how to
> tell libgdal to ignore any Windows/System32/*.dll
-> workaround in the ticket
>> https://trac.osgeo.org/grass/ticket/820
> Proposed fix for OSGEO4W: add msys bash because from within the
> OSGEO4W msys (the one you get when starting grass with msys console),
> there is no /bin/bash
-> r.in.wms should not hold a release.
>> https://trac.osgeo.org/grass/ticket/555
>> v.in.gpsbabel on WinGrass + a GPX file as in #555 is a quick test:
-> closed, too.
> No blockers left for Linux, it's ready, IMHO.
Good. So only two blockers left (see above).
Markus
