[GRASS-dev] GRASS6.4 Ptyhon scripts- module
Markus Neteler
neteler at osgeo.org
Tue Jul 27 04:14:24 EDT 2010
2010/6/23 Glynn Clements <glynn at gclements.plus.com>:
> António Rocha wrote:
>> > 6.4 has the Python modules, but the build system doesn't support
>> > Python scripts (it doesn't set PYTHONPATH when executing commands).
>> What does this means? That I won't be able to run Python Scripts in 6.4?
> You can run a Python script once you've managed to install it, but you
> can't just drop it into the source tree, as the 6.x build system
> doesn't support Python scripts.
what is missing - any pointers?
Markus
