[GRASS-dev] 6.4.0 blocker bugs
Glynn Clements
glynn at gclements.plus.com
Tue Jul 27 23:19:20 EDT 2010
Hamish wrote:
> Markus Neteler wrote:
> > -> r.in.wms should not hold a release.
> fwiw, r.in.wms and (presumably) i.oif on WinGrass do not work right now
> because they use helper shell scripts installed to $GISBASE/etc/$module/
> and those shell scripts do not currently have associated .bat files to
> launch them so they aren't executable and so not found in the %PATH%.
> should be an easy fix to generate those batch files in the two modules'
> Makefiles, but so far it remains TODO.
I'm not sure that they should need .bat files, given that they are
only run from within a shell scripts. I thought that MSys could handle
this itself.
Does it work if the main scripts are changed to run helper scripts via
an absolute path?
