[GRASS-dev] grass7 on mac OSX
Helena Mitasova hmitaso at unity.ncsu.edu
Tue Jun 1 19:39:08 EDT 2010
On Jun 1, 2010, at 5:52 PM, Barton Michael wrote:
> I just compiled GRASS 7 a couple days ago, before leaving for Spain. Wx digitizer and nviz don't compile.
I had the same problem two days ago - I will update and try again.
Everything else runs so far but I really wanted to check on the new wxnviz development.
Helena
> Also others can't even open my binaries.
> Is there a new configure switch for ctypes? Are we supposed to no longer use the python switch?
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Jun 1, 2010, at 11:36 PM, Massimo Di Stefano wrote:
>> Now the error i means :
>>>>> In [2]: from grass.lib import raster
>>>>> Traceback (most recent call last):
>>>>> File "<ipython console>", line 1, in <module>
>>>>> ImportError: No module named lib
>> is reflected in the gui.
>> the new GUI code changes are affected by it,
>> tring to build grass70, starting the application
>> i have a broken gui that show me this error log :
>> GRASS 7.0.svn (spearfish60):~ >
>> WARNING: Vector digitizer is not available (dlopen(/Applications/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/vdigit/_grass7_wxvdigit.so, 2): Symbol not found: __Py_RefTotal
>> Referenced from: /Applications/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/vdigit/_grass7_wxvdigit.so
>> Expected in: flat namespace
>> in /Applications/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/vdigit/_grass7_wxvdigit.so).
>> Note that the vector digitizer is currently not working under MS Windows (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS.
>> File "/Applications/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/wxgui.py", line 87, in <module>
>>   import gui_modules.nviz_tools as nviz_tools
>> File "/Users/Shared/source/grass_trunk/dist.i386-apple-darwin10.3.0/etc/gui/wxpython/gui_modules/nviz_tools.py", line 36, in <module>
>>   from nviz_mapdisp import wxUpdateView as wxUpdateView
>> File "/Users/Shared/source/grass_trunk/dist.i386-apple-darwin10.3.0/etc/gui/wxpython/gui_modules/nviz_mapdisp.py", line 41, in <module>
>>   import wxnviz
>> File "/Users/Shared/source/grass_trunk/dist.i386-apple-darwin10.3.0/etc/gui/wxpython/gui_modules/wxnviz.py", line 24, in <module>
>>   from grass.lib.grass import *
>> ImportError: No module named lib.grass
>> tring to re-run :  "g.gui" i have the same log.
>> just to check if my python "is bugged"
>> i build python2.6.5 source code,
>> in a non standard location "/usr/local/gislib/unix",
>> as unix library (no framework)
>> then i exported the path for the new python
>> and i used it to reconfigure-compile-install grass70,
>> but unluky i have problems to build wxpython
>> (i compiled wxwidjet as 32+64 bit but i'm having
>> problems  to built wxpython on it)
>> i'll try to figure out a wxpython cocoa build
>> and tell you if the grass.lib  not found problem persists.
>> thanks for any help.
>> Il giorno 27/mag/2010, alle ore 16.52, Michael Barton ha scritto:
>>> No ipython on the student's machine.
>>> I compiled GRASS 7 and had no problems. I posted my binary so others could use it. The one person who has tried it gets a bogus error about Python subprocess() not existing. The binary of GRASS 6.5 that I compiled and posted at the same time runs fine on her machine (demonstrating that subprocess() is OK).
>>> Oddly, some other folks here got similar bogus errors with GRASS 6.5 or 7 (I can't remember) when trying to run a Python script under winGRASS a few weeks back.
>>> Michael
>>> C. Michael Barton
>>> On May 27, 2010, at 6:43 AM, William Kyngesburye wrote:
>>>> On May 27, 2010, at 3:56 AM, Massimo Di Stefano <massimodisasha at gmail.com
>>>>> wrote:
>>>>> Hell Soeren,
>>>>> seems i've an up-to-date revision :
>>>>> MacBook-Pro-15-di-Massimo-Di-Stefano:grass_trunk sasha$ svn up
>>>>> At revision 42358.
>>>>> i also did make distclean first to re-try configure && make.
>>>>> but your note about a "renamed" function, point me to a problem i
>>>>> had on qgis side too (make install overwrite the .app but ... it
>>>>> don't do it as aspected)
>>>>> infact, removing manually the old grass70.app (compiled from source)
>>>>> trashing the complete app from /Application , instead of overwrite
>>>>> it using "sudo make install"
>>>>> now i have :
>>>>> In [1]: import os, sys
>>>> I wonder if ipython is affecting this?  Just a random idea. (I can't
>>>> try anything right now- dev Mac died)
>>>>> the error is present but changes ... this time maybe can be a wrong
>>>>> sintax i used ???
>>>>> weird .. i'm a bit confused ;-)
>>>>> i'm tring to replicate, from command line, the code :
>>>>> import os, sys
>>>>> from grass.lib import grass, raster
>>>>> from ctypes import *
>>>>> input = sys.argv[1]
>>>>> grass.G_gisinit(sys.argv[0])
>>>>> mapset = grass.G_find_raster2(input, "")
>>>>> print mapset
>>>>> Massimo
>>>>> Il giorno 27/mag/2010, alle ore 10.37, Soeren Gebbert ha scritto:
>>>>>> Hello Massimo,
>>>>>> can you please make a svn update?The gmath function
>>>>>> G_math_backward_solving has been renamed into
>>>>>> G_math_backward_substitution a while ago. Maybe something got mixed
>>>>>> up?
>>>>>> Best
>>>>>> Soeren
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
