[GRASS-dev] WinGrass65 + import gui_modules.nviz_tools as nviz_tools: ImportError
Helmut Kudrnovsky hellik at web.de
Sat Jun 5 03:42:17 EDT 2010
-----Ursprüngliche Nachricht-----
Von: Helmut Kudrnovsky
Gesendet: 05.06.2010 09:32:33
An: Glynn Clements
Betreff: Re: [GRASS-dev] WinGrass65 + import gui_modules.nviz_tools as nviz_tools: ImportError
>>Von: Glynn Clements
>>Gesendet: 05.06.2010 07:34:47
>>An: Helmut Kudrnovsky
>>>Helmut Kudrnovsky wrote:
>> >WARNING: Nviz extension (3D view mode) disabled. Reason: grass_datetime not found.
>>Does PATH include the %WINGISBASE%\lib directory? And does
>>libgrass_datetime.dll exist in that directory?
>I'm using script package.sh
>(http://trac.osgeo.org/grass/browser/grass/trunk/mswindows/osgeo4w/package.sh)
>- which also uses the nightly build - for building WinGrass7 in the osgeo4w-stack.
>after compiling there are in C:\OSGeo4W\usr\src\grass_trunk\dist.i686-pc-mingw32\lib
>all libgrass*.dlls, fmode.o and libgrass_iostream.a.
>package.sh also does "make install", but after that in the installfolder
>C:\OSGeo4W\apps\grass\grass-7.0.svn\lib
>there is only fmode.o and libgrass_iostream.a,
>but there isn't any libgrass*.dll.
>the nightly Wingrass7-installer is build on top of C:\OSGeo4W\apps\grass\grass-7.0.svn\
>and therefore there aren't also any libgrass*.dlls.
after copying manually for testing all the libgrass*.dlls in C:\Program Files\GRASS-70-SVN\lib
there is following message:
"WARNING: Nviz extension (3D view mode) disabled. Reason: intl not found."
Helmut
___________________________________________________________
NEU: WEB.DE DSL für 19,99 EUR/mtl. und ohne Mindest-Laufzeit!
http://produkte.web.de/go/02/
