[GRASS-dev] Re: grass-dev Digest, Vol 50, Issue 11
Barton Michael michael.barton at asu.edu
Sat Jun 5 17:46:19 EDT 2010
I've been tied up with ABM classes and with a dissertation defense Monday. But I'm trying to keep tabs on this and will try to compile again soon. Sounds like there are still problems, but getting closer.
Michael
On Jun 5, 2010, at 6:00 PM, grass-dev-request at lists.osgeo.org wrote:
> Date: Sat, 5 Jun 2010 10:02:22 -0500
> From: William Kyngesburye <woklist at kyngchaos.com>
> Subject: Re: [GRASS-dev] grass7 on mac OSX
> To: Glynn Clements <glynn at gclements.plus.com>
> Cc: "grass-dev at lists.osgeo.org list" <grass-dev at lists.osgeo.org>
> Message-ID: <FBDFC367-9F25-4FBC-8650-A825BF3BE707 at kyngchaos.com>
> Content-Type: text/plain; charset=us-ascii
> On Jun 5, 2010, at 1:15 AM, Glynn Clements wrote:
>>> With, though I get that unknown architecture
>>> error in nviz.py.  The ctypesgen authors seem to be aware of and patch
>>> OSX issues, but maybe they never tried it with system framework headers.
>> But does this prevent the generation of the wrapper?
>>> There are more similar CF_INLINE definitions earlier, but they are
>>> inside a #ifdef CF_INLINE.
>> But do these prevent the wrapper from being generated, or result in it
>> missing necessary definitions?
>> ctypesgen ignores errors from the preprocessor (it doesn't capture
>> stderr and doesn't care about the exit code). Errors only matter
>> insofar as they cause significant declarations to be omitted or
>> malformed.
>> The ValueError is different as that's an exception being raised within
>> ctypesgen itself; r42484 should deal with that.
> Ah, it's generated.
> Next error, after that finishes:
> sed \
>        -e '/^# End loader$/a\
>        from ctypes_preamble import *\
>        from ctypes_preamble import _variadic_function\
>        from ctypes_loader import *' \
>        -e '/^# Begin preamble$/,/^# End preamble$/d' \
>        -e '/^# Begin loader$/,/^# End loader$/d' \
>        date.py > /Users/Shared/src/GRASS/svn/trunk/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/date.py
> sed: 1: "/^# End loader$/afrom c ...": command a expects \ followed by text
> make[2]: *** [/Users/Shared/src/GRASS/svn/trunk/dist.i386-apple-darwin10.3.1/etc/python/grass/lib/date.py] Error 1
> There is only 1 file after this in dist/etc/python/grass/lib: an empty date.py.
> I never had any luck on OSX with newlines in sed replacement strings in makefiles.  It'll work in shell scripts but not makefiles.
